Standalone Database¶
Managed Database is an often used managed service. SeaTable can easily be configured to use a separate database. We recommend to initialize SeaTable with the default mariadb container. Then dump the database, load the dump to a separate database, update the .env file and restart SeaTable. Due to this assumption, this manual is the same for a new SeaTable Server or a service where you want to migrate the database.
Stop SeaTable¶
docker stop seatable-server
Now you can be sure, that no more records are written or modified in the database.
Dump and restore to another database¶
Please refer to Backup and Recovery for instructions regarding the backup process for the MariaDB database.
You can use the mariadb CLI to import the contents of the dumped databases into the managed databases.
Stop Mariadb¶
After the dump, stop also the database container:
docker stop mariadb
Don't start mariadb container¶
Create a copy of seatable-server.yml and rename it to custom-seatable-server.yml. You should remove the mariadb service definition and update the depends_on declaration for the seatable-server service to ensure that it can start up.
services:
seatable-server:
depends_on:
mariadb: # < remove
condition: service_healthy # < remove
mariadb: # remove complete service
... # with all lines
Update environment variables¶
You should update/set the following environment variables in your .env file:
MARIADB_HOST=
MARIADB_PORT=
MARIADB_PASSWORD=
Restart SeaTable¶
After that you can restart SeaTable.
Troubleshooting¶
Check the logs and look for any connection errors.
tail -f /opt/seatable-server/seatable/logs/*.log
Remove old database¶
if everything is running good, you can delete the local database folder /opt/mariadb.
rm -r /opt/mariadb
