Running SeaTable without Hairpin NAT¶
Some networks and routers do not support hairpin NAT (also called NAT loopback or NAT reflection). This prevents Docker containers from resolving and accessing SeaTable via its external hostname from within the local network. Without a workaround, this breaks internal container-to-container communication, causing failures like Python scripts (e.g., automation tasks) and PDF generation to stop working.
The workaround is to install a local DNS service dnsmasq, set up a DNS resolution for the url of your seatable server and then to configure that all docker containers use this dns service.
Step 1: Install and Configure dnsmasq¶
Install dnsmasq and create a configuration that resolves your SeaTable hostname locally to the container's gateway IP.
# Ubuntu/Debian
sudo apt update
sudo apt install dnsmasq
# Add SeaTable hostname resolution (replace 'seatable.example.com' and gateway IP)
echo "address=/seatable.example.com/172.17.0.1" >> /etc/dnsmasq.conf
# Restart dnsmasq
sudo systemctl restart dnsmasq
sudo systemctl enable dnsmasq
Step 2: Configure Docker Daemon¶
Edit Docker's configuration and add the following configuration to use the local dnsmasq as resolver. If the file /etc/docker/daemon.json does not exist, create it. Instead of 8.8.8.8 you can use any other public DNS server.
"dns": ["127.0.0.1", "8.8.8.8"]
After saving, restart docker with sudo systemctl restart docker
Step 3: Verify and Restart SeaTable¶
Test resolution inside a container and restart SeaTable.
# Test DNS resolution (should resolve to gateway IP)
docker run --rm --dns 127.0.0.1 busybox nslookup seatable.example.com
# Restart all containers
cd /opt/seatable-compose
docker-compose down
docker-compose up -d
Troubleshooting¶
- Check dnsmasq logs:
journalctl -u dnsmasq?. - Verify
DTABLE_SERVER_URLindtable_web_settings.pyuses the external hostname only. - Ensure no conflicting DNS servers on port 53; stop
systemd-resolvedif needed:sudo systemctl disable --now systemd-resolved.
This setup ensures all containers resolve the SeaTable hostname correctly without hairpin NAT.
