Force http only for your SeaTable Server¶
Force http during installation¶
It is not recommended to run SeaTable without https. Still it is possible. During the installation it is sufficient to set the .env variable SEATABLE_SERVER_PROTOCOL with the value http and all configuration files and caddy will be set up correctly.
Switching after the installation¶
If you want to force http after the initial setup, you also have to adapt these configuraton files and replace all https:// values with http://:
- dtable_web_settings.py
- ccnet.conf
- nginx.conf
Especially the change of the nginx file is not trivial, if you don't have any experience with nginx.
