Skip to content
IP Access Restriction
By default, your SeaTable Server is accessible from any IP address. This article explains how to limit access to a list of allowed IP addresses (allowlist) or how to block single IP addresses (blocklist). Requests from all other IP addresses are answered with 403 Forbidden.
The restriction is done by Caddy. You don't have to modify seatable-server.yml or caddy.yml. Instead, you add one additional yml file and one file containing your IP addresses. This keeps your changes intact during updates.
Public features are restricted too
The restriction applies to every request. Users with a non-allowed IP address can't use any features that are meant to be public, for example:
  • Forms (/dtable/forms/...)
  • External links and shared views
  • Universal Apps
  • API requests from external services like n8n Cloud, Make or Zapier
Make sure to add the IP addresses of all users and services that need access.
Configure an allowlist
Step 1: Create the file with your allowed IP addresses
Create a new directory caddy-snippets inside /opt/seatable-compose and add a file ip-allowlist.caddy:
mkdir -p /opt/seatable-compose/caddy-snippets
nano /opt/seatable-compose/caddy-snippets/ip-allowlist.caddy
Insert the following content and replace the example IP addresses with your own:
@blocked {
    # Office
    not remote_ip 203.0.113.10
    # VPN gateway
    not remote_ip 198.51.100.0/24
    # Home office (multiple addresses can be separated by spaces)
    not remote_ip 192.0.2.44 192.0.2.45
    # Docker networks, required for components on the same host
    not remote_ip private_ranges
handle @blocked {
    respond 403
Explanation
  • Every line not remote_ip ... accepts one or more IP addresses or CIDR ranges, separated by spaces.
  • All lines must match for a request to be blocked. In other words: a request is blocked if its IP address is not part of any line.
  • Lines starting with # are comments.
  • private_ranges covers all private and loopback networks (e.g. 10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16, 127.0.0.0/8). Components like Collabora Online, OnlyOffice, SeaDoc or the Python Pipeline call your SeaTable Server via its public URL. These requests reach Caddy with an internal Docker IP address and would be blocked without this line.
Use handle, not respond
You might find examples that only use respond @blocked 403. Don't use this, it leaves gaps. Caddy executes route blocks before respond, and some components add routes that forward requests directly to another container. For example, seatable-html-server.yml adds such a route for /app-server/*. With respond, this path stays accessible for every IP address. handle is executed before route and therefore blocks these paths as well.
Server in a private network
If your server is located in a private network (e.g. your company LAN), private_ranges allows every client from this network. In this case, replace private_ranges with the Docker networks only (usually 172.16.0.0/12) and add the allowed LAN addresses explicitly.
Step 2: Create custom-ip-allowlist.yml
Create a new file /opt/seatable-compose/custom-ip-allowlist.yml with the following content:
services:
  caddy:
    volumes:
      - ./caddy-snippets:/etc/caddy/custom:ro
  seatable-server:
    labels:
      caddy_0.import: /etc/caddy/custom/ip-allowlist.caddy
This mounts the directory caddy-snippets into the Caddy container and imports your IP list into the configuration of SeaTable Server. Docker Compose merges these settings with caddy.yml and seatable-server.yml.
Mount the directory, not the file
Please mount the directory and not only the file. Many editors (like vim) replace a file when saving it. A container with a single-file mount would continue to see the old version of your file.
Step 3: Add custom-ip-allowlist.yml to your .env file
Existing installations
Earlier versions of this guide used the name ip-allowlist.yml. You can keep this name, it works the same way.
custom-ip-allowlist.yml must be the last entry of the COMPOSE_FILE variable inside your .env file:
sed -i "s/COMPOSE_FILE='\(.*\)'/COMPOSE_FILE='\1,custom-ip-allowlist.yml'/" /opt/seatable-compose/.env
Step 4: Apply the changes
Run the following command inside /opt/seatable-compose:
docker compose up -d
Check the logs of Caddy for errors:
docker logs caddy 2>&1 | grep -i "invalid block"
A syntax error disables SeaTable
If your ip-allowlist.caddy contains a syntax error, Caddy removes the complete configuration of your SeaTable Server, and SeaTable is no longer accessible. The logs show a message like Removing invalid block: parsing caddyfile tokens for 'handle' .... Fix your file and apply the changes again.
Test the restriction
Run the following commands from a computer with a non-allowed IP address (e.g. a smartphone hotspot). Replace seatable.example.com with your domain:
curl -s -o /dev/null -w '%{http_code}\n' https://seatable.example.com/
curl -s -o /dev/null -w '%{http_code}\n' https://seatable.example.com/api2/ping/
Both commands must return 403. From an allowed IP address, you get 302 and 200, and SeaTable works as usual.
Restrict additional components
Components like Collabora Online or n8n are accessible via their own ports. Each component has its own Caddy configuration, which is not covered by the restriction of SeaTable Server. If you want to restrict these components as well, add their services to custom-ip-allowlist.yml. Please note that these services use the label prefix caddy instead of caddy_0:
services:
  caddy:
    volumes:
  seatable-server:
    labels:
  collabora:
    labels:
      caddy.import: /etc/caddy/custom/ip-allowlist.caddy
  n8n:
    labels:
These are the service names of the components with their own ports:
Component yml file Service name Default port
Gatus gatus.yml gatus 6220
Uptime Kuma uptime-kuma.yml uptime-kuma 6230
n8n n8n.yml n8n 6231
Collabora Online collabora.yml collabora 6232
OnlyOffice onlyoffice.yml onlyoffice 6233
Zabbix zabbix.yml zabbix-web 6235
tldraw tldraw.yml tldraw-worker 6239
SeaDoc seadoc.yml seadoc 6240
Dozzle dozzle.yml dozzle 6241
Only add services you actually use
Only add services whose yml file is part of COMPOSE_FILE. Otherwise docker compose stops with an error like service "collabora" has neither an image nor a build context specified.
gatus.yml adds a redirect from /status to the Gatus port. This redirect is executed before the IP check and therefore stays accessible for every IP address. Add the import to the gatus service to protect the status page itself.
Update the list of IP addresses
Caddy does not notice changes to ip-allowlist.caddy automatically. After you have changed the file, reload the configuration of Caddy:
docker exec caddy caddy reload --config /config/caddy/Caddyfile.autosave --adapter caddyfile
The reload applies the new list without any interruption. If your file contains an error, the reload is aborted with an error message and the previous configuration stays active.
Alternatively, you can restart Caddy with docker compose restart caddy. This takes a few seconds, your certificates are kept.
Let's Encrypt
Let's Encrypt keeps working without any further configuration. Caddy answers the ACME challenges for your certificates before your IP check is executed:
  • HTTP-01 challenges on port 80 are answered internally by Caddy. The restriction is only added to the HTTPS configuration.
  • TLS-ALPN-01 challenges on port 443 are answered during the TLS handshake, before any HTTP rule is evaluated.
There is no need to open the restriction for the IP addresses of Let's Encrypt.
IPv6
If you only allow IPv4 addresses, make sure your domain has no AAAA record. You can check this with:
dig AAAA seatable.example.com +short
If the command returns an IPv6 address, users with IPv4 and IPv6 connect via IPv6. Caddy sees their IPv6 address, which is not on your list, and blocks them. Either remove the AAAA record or add the IPv6 addresses or ranges of your users to ip-allowlist.caddy.
If you use IPv6, IPv6 must be enabled for the Docker network of Caddy. Otherwise, Caddy only sees the IP address of the Docker gateway for every IPv6 request. Read more about this in Activate IPv6.
Configure a blocklist
You can also use the opposite approach and block single IP addresses, while all other IP addresses keep access. Remove the not from your ip-allowlist.caddy:
@blocked {
    # Scanner
    remote_ip 203.0.113.10 203.0.113.11
    # Network of a hosting provider
handle @blocked {
    respond 403
In this case, a request is blocked if its IP address matches any of the lines. All other steps are identical.
A blocklist offers limited protection
A blocklist only blocks IP addresses you already know. Every other IP address keeps access, including requests via IPv6 if your domain has an AAAA record. If you need to protect your server against brute-force attacks, consider tools like fail2ban or CrowdSec.
