S3 Encryption¶
SeaTable supports SSE-C (server-side encryption with customer-provided keys) to encrypt objects stored inside the S3 buckets at rest. This applies to both base snapshots and the content of file and image columns.
Incompatibility with Ceph-based object storage providers
Please note that certain object storage providers that are based on Ceph (e.g. Hetzner Object Storage) currently do not support CopyObject operations when using SSE-C. This makes them incompatible with SeaTable. There is an open issue over at the Ceph issue tracker.
Configuration¶
To encrypt both base snapshots and assets, you must configure a valid encryption key in two locations:
dtable-storage-server.confto encrypt base snapshotsseafile.confto encrypt the files stored in file and image columns
These encryption keys can be different.
Key Generation¶
SeaTable requires an encryption key that is exactly 32 characters long.
You can generate a valid key with the following command:
openssl rand -base64 24
Losing your SSE-C key results in permanent data loss
You should make sure to store the encryption key in a safe location. Losing the key will result in permanent data loss of all encrypted objects. Since the cloud storage provider does not store the key (instead, SeaTable provides the key with every request), there's no way to recover the data since the actual objects are encrypted at rest.
CLI Usage
CLI tools such as mc will reject a key generated using the openssl command displayed above. They require you to encode the key as base64. This can be achieved with the following command:
# printf ensures that there's no trailing newline character
printf 'KEY_GENERATED_BY_OPENSSL' | base64
In addition, you must strip any trailing = signs at the end of the key that are used for padding before passing the key to mc commands such as mc put or mc get.
Base Snapshots¶
To encrypt base snapshots at rest, you must configure an encryption key inside dtable-storage-server.conf:
[storage backend]
sse_c_key = YOUR_ENCRYPTION_KEY
You must restart SeaTable after applying this configuration change:
docker restart seatable-server
Assets¶
To encrypt the file assets stored in file and image columns, you must configure an encryption key inside seafile.conf for all three object types (commits, fs and blocks):
[commit_object_backend]
[fs_object_backend]
[block_backend]
Migration¶
Any objects stored before enabling SSE-C won't be accessible after restarting SeaTable since SeaTable does not keep track whether a certain object is encrypted or not. This requires you to manually encrypt the objects with the configured encryption key.
The easiest way to achieve this is to copy all objects to separate buckets with enabled encryption. However, certain object storage providers such as Exoscale do not support mirroring objects between buckets with differing encryption configuration settings.
As a workaround, you can download all objects to the local filesystem before uploading them again with enabled encryption.
This can be achieved with the following mc commands:
mc mirror ${ALIAS}/block1 /tmp/block1 --summary
mc mirror /tmp/block1 ${ALIAS}/block2 --summary --enc-c "${ALIAS}/block2/=${ENCRYPTION_KEY}"
mc mirror ${ALIAS}/commit1 /tmp/commit1 --summary
mc mirror /tmp/commit1 ${ALIAS}/commit2 --summary --enc-c "${ALIAS}/commit2/=${ENCRYPTION_KEY}"
mc mirror ${ALIAS}/fs1 /tmp/fs1 --summary
mc mirror /tmp/fs1 ${ALIAS}/fs2 --summary --enc-c "${ALIAS}/fs2/=${ENCRYPTION_KEY}"
mc mirror ${ALIAS}/storage1 /tmp/storage1 --summary
mc mirror /tmp/storage1 ${ALIAS}/storage2 --summary --enc-c "${ALIAS}/storage2/=${ENCRYPTION_KEY}"
Note
${ALIAS}refers to the configuredmcaliasblock1,commit1,fs1andstorage1refer to the old buckets with unencrypted objectsblock2,commit2,fs2andstorage2refer to the new buckets that contain encrypted objects
Afterwards, you must update the bucket names inside dtable-storage-server.conf and seafile.conf and restart SeaTable to apply the configuration changes:
