Prerequisites¶
This following guides assume that you have a fully functioning SeaTable Server installation and have successfully installed SeaTable AI.
LLMs are resource-intensive
Running an LLM requires significant computing resources. While the exact requirements depend on the chosen model, our internal tests have shown that LLMs with less than 8 billion parameters do not yield useful results for the use cases we looked at. Therefore, we recommend that you choose a model with at least 8-12 billion parameters. Generally speaking, this will require at least 16GB of VRAM (or more, depending on the configured context window size). While you can run AI models on a CPU, performance (measured in tokens per second) will be much worse compared to running the same model on a powerful GPU.
GPU Usage¶
Requirements depend on your GPU make/model
You can refer to Ollama's documentation for instructions regarding GPU usage. Depending on your GPU, this will require installing proprietary NVIDIA drivers and the NVIDIA Container Toolkit or adding additional arguments to the .yml files shown in the following guides.
For Debian-based systems with NVIDIA GPUs, the following steps were carried out to successfully deploy Ollama and vLLM:
- Install the proprietary NVIDIA drivers. The Debian Wiki contains installation instructions for the latest Debian releases.
- Remember to restart your system before proceeding with the following steps.
- Install the NVIDIA Container Toolkit.
