Skip to content
Using Let's Encrypt with DNS Challenge (caddy-dns) Instead of HTTP Ports 80/443
By default, SeaTable uses Caddy with the HTTP-01 challenge method to automatically request and renew a Let's Encrypt certificate. This approach requires that ports 80 and 443 are publicly reachable so that Let's Encrypt can validate domain ownership.
In environments where these ports cannot or should not be exposed (e.g. internal installations, restrictive firewalls, or isolated networks), you can alternatively use the DNS-01 challenge via the caddy-dns plugins.
Advantages and Requirements of DNS Challenge
When using the DNS challenge:
  • No inbound HTTP/HTTPS access from the internet is required.
  • The system does not need to be publicly reachable.
  • Certificate validation happens via DNS TXT records.
Custom Caddy build required
This setup requires building a custom Docker image that includes:
  • the appropriate DNS provider plugin
  • the caddy-docker-proxy plugin
Therefore, this configuration is intended for advanced administrators who are familiar with managing DNS zones and understand DNS propagation behavior.
DNS-Provider support is mandatory
caddy-dns supports many common DNS providers (e.g. Hetzner, Cloudflare, Route53 and others). A full list is available in the official repository: caddy-dns
Make sure your DNS provider is supported. Otherwise, this setup will not work.
Depending on your provider, you may need:
  • An API token
  • API key and secret
  • A dedicated DNS API user
  • Appropriate zone permissions
Step 1: Replace the Default Caddy Configuration
Instead of using the default caddy.yml, create a new YAML file that builds a custom Caddy container.
Your custom Caddy must include two plugins:
  • lucaslorentz/caddy-docker-proxy
  • caddy-dns/your-dns-provider
You can find the correct plugin name for your DNS provider at: https://github.com/caddy-dns
Even though ports 80 and 443 are still mapped internally, they do not need to be publicly reachable for DNS-01 validation.
Below is an example using the Hetzner DNS plugin:
services:
  caddy:
    build:
      dockerfile_inline: |
        ARG CADDY_VERSION=2.10.2
        FROM caddy:$${CADDY_VERSION}-builder AS builder
        RUN xcaddy build \
            --with github.com/lucaslorentz/caddy-docker-proxy/v2 \
            --with github.com/caddy-dns/hetzner/v2
        FROM caddy:$${CADDY_VERSION}-alpine
        COPY --from=builder /usr/bin/caddy /usr/bin/caddy
        CMD ["caddy", "docker-proxy"]
    container_name: caddy
    restart: unless-stopped
    environment:
      - CADDY_INGRESS_NETWORKS=frontend-net
    networks:
      - frontend-net
    ports:
      - 80:80
      - 443:443
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - ./volumes/caddy:/data
networks:
  frontend-net:
Step 2: Configure TLS for SeaTable
Next, configure Caddy to use the DNS challenge by adding the caddy.tls labels to your SeaTable service definition.
The exact configuration depends on your DNS provider. In most cases, the API token must have permission to manage DNS records for the corresponding zone.
caddy_0.tls.dns: "hetzner ${HETZNER_DNS_TOKEN:?Variable is not set or empty}"
caddy_0.tls.propagation_delay: 30s
caddy_0.tls.dns: "cloudflare {CLOUDFLARE_API_TOKEN:?Variable is not set or empty}"
Step 3: Create and Configure the DNS API Token
Log in to your DNS provider’s account and generate an API token with permission to manage DNS records for the required zone.
The required permissions for each provider are typically documented in the corresponding plugin directory at: https://github.com/caddy-dns.
Add the generated token to your .env file, for example:
# Caddy DNS-01 challenge
HETZNER_DNS_TOKEN=your_token_here
CLOUDFLARE_API_TOKEN=your_token_here
After restarting the Caddy container, Caddy will automatically:
  1. Request or renew the certificate from Let's Encrypt
  2. Create the required _acme-challenge TXT record via the DNS API
  3. Wait for DNS propagation
  4. Complete validation and remove the temporary record
No public inbound access to ports 80 or 443 is required for this process.
