Security settings¶
Accept headers¶
Our default deployment enforces strict security headers, which prevent the loading of images or scripts from external URLs. This approach is designed to enhance security and protect against fraudulent activities.
If you are running your own server, you have the option to modify these security headers to allow additional sites to interact with your SeaTable server.
To adjust these settings, you can modify the seatable-server.yml file located at /opt/seatable-compose/seatable-server.yml. The default configuration might look like this:
caddy.header.Content-Security-Policy: "`
block-all-mixed-content;
default-src 'none';
style-src 'unsafe-inline' 'self';
script-src 'unsafe-inline' 'unsafe-eval' 'self';
script-src-elem 'unsafe-inline' 'self' ${SEATABLE_SERVER_HOSTNAME}:${ONLYOFFICE_PORT:-6233} maps.googleapis.com;
font-src 'self' data:;
img-src 'self' data: blob: https: market.seatable.io mt0.google.com maps.googleapis.com maps.gstatic.com;
form-action 'self' ${SEATABLE_SERVER_HOSTNAME}:${COLLABORA_PORT:-6232};
connect-src 'self' market.seatable.io https:;
frame-src 'self' ${SEATABLE_SERVER_HOSTNAME}:${COLLABORA_PORT:-6232} ${SEATABLE_SERVER_HOSTNAME}:${ONLYOFFICE_PORT:-6233};
frame-ancestors 'self';
worker-src 'self' blob:;
manifest-src 'self';
object-src 'self';
base-uri 'self'
Create a custom copy of your seatable-server.yml file and modify these settings according to your specific requirements. Don't forget to link the new yml file in your .env file.
Cookies¶
Secure cookies require additional configuration
To get these ratings, it is required to add two more options to dtable_web_settings.py. In one of the next versions, these parameters will probably be added by default.
CSRF_COOKIE_SECURE = True
SESSION_COOKIE_SECURE = True
DNSSEC¶
It also requires DNSSEC from your domain hoster to get the best security measures.
